Hi there can anyone help me i want to fit a momo wheel
Postby Anthony Hoyland » Thu Feb 07, 2008 19:06
Hi there evryone i am having a few problems i am trying to fit a momo steering wheel to my suzuki x90. It as air bags and when you take the wheel of the air bag light comes on the dash and once you remove the wheel there is a modual behined the wheel with a big conecter with the horn wire coming out and a air bag wire can any one help me so i can fit my momo to my pride ad joy THANKS :(
Regards Anthony
Anthony Hoyland
Postby Ian Linden » Thu Feb 07, 2008 22:31
I do not recommend this, as you will have to lose the airbag.
However, if you must, you need to remove the airbag fuse (a separate yellow fuseholder under the dash) and then unplug the airbag (a yellow connector under the dash). Then remove the airbag. Now airbags are a potential hazard, and must be professionally disarmed and disposed of, so I think you should take it to a garage where they know what they are doing.
If you do remove the airbag yourself, hold it at arms length, so that, in the event that it triggers, it does not injure you.
But, to repeat, I recommend that you do not do it.
