Powerflow stainless steel cat-back exhaust pipe for sale (mild steel flange)..
1-3/4” with a 4” double skin tail pipe, burbles quite nicely and a bit louder than standard.
Covered 3300 mile since installed in May 03
Removed May 05 due to bodykit
PLEASE NOTE There is a bit of moderate DIY modifications are required to make the exhaust fit. About 200mm of centre section was cut off and binned! I have had a piece made up as close as possible without the exhaust being put onto a car to replace the bit removed and as a minimum 1 cut will have to be made when the exhaust is on a car. At the worst a bit of welding will be required.
If you are intending to pick up the exhaust I can point you in the direction of my local Powerflow centre who are prepared to remove your old unit, install this one and do all the necessary mods. In addition you will more than likely get the lifetime guarantee as well. If you are interested I will verify and get some sort of idea of cost.
£150 + P&P I would prefer collection as they are not the lightest or easiest of things to post!
I have photo’s if you are genuinely interested, please PM me with your email address.
