by Ian Linden » Fri Oct 12, 2007 15:06
Well, I think my manual X-90 is fairly nippy for its weight, but it's no sports car. It does respond to high rpm, but runs out of steam at about 65 (partially due to me having Vitara size tires and not having changed the final drives for a lower ratio).
I think that, at lower speeds, the auto box may well give better response, because the torque converter can give the effect of a lower drive ratio. The real test is something like the time taken from 60 to 70 mph.
As for improving the power, there is nothing cheap. Adding a turbo is a bespoke job for an expert, and would cost thousands. A better route would be to fit a 2.5 litre V6 out of a GV, complete with gearbox. But doing it to an auto would be a real headache, because of the electrics.
