Capuccinno ECM
Cappuccino related 'For Sale' and 'Wanted' Advertisements
Capuccinno ECM
Postby Ian Stanyon » Tue Aug 30, 2016 12:43
I am looking for a working ECM to check against one that may or may not be faulty. The Check engine warning light is on but we cannot trace any faults through the blink codes shown in the workshop manual. I need to check against a known working unit so would purchase if one is available. Alternatively, is there anywhere that can check and remap the original to a working condition?
many thanks,
Ian Stanyon
Ian Stanyon
Re: Capuccinno ECM
Postby Ian Linden » Thu Sep 01, 2016 23:22
If the fault lamp only lights when the engine runs, you must try reading the code without turning off the ignition, as the ECU does not store codes.
Are you sure you connected C to D as shown on Page 6E-32 ?
If you did not get a valid trouble code, did it show Code 12 ?
http://www.the-ecu-doctor.co.uk/ is generally recommended.
Return to Classifieds
