Parts book
Parts book
Postby Collette Dobson » Sun Jan 19, 2025 22:22
I just came here looking for the Cappo parts book, but I can't find any of the reference material. It has been a while so has it been moved elsewhere? Failing that where is the best place to find parts diagrams? I am looking for detail on the steering column. Thanks.
Images: 5
Re: Parts book
Postby Ian Linden » Tue Jan 21, 2025 18:04
Hi Collette,
Nothing has moved. The parts Catalogues are reached by clicking "Manuals" at the very top of the screen, above the banner.
You want Fig 56, under "Suspension & Brakes"
Re: Parts book
Postby Murray Betts » Thu Jan 23, 2025 15:28
Just in case Collette, if you are getting a "clicking" noise/feel from the steering column, I posted a while ago about adjusting and lubricating the steering rack damper ("yoke"). It's under a white nylon screw-in plug (large square piece on the top to turn with a spanner etc) on the front of the rack on the driver's side. I think it should have a cap over it but mine hasn't. It's visible and just reachable from the front of the car with the bonnet open, down low below the alternator.
I lubed mine with a mix of gear oil and moly grease, as suggested on an Alfa forum I think. There's a spring under the white plug and a friction plunger (the yoke), but the spring preload is only slight, no fears of exploding parts when you undo it. The spring and yoke press the rack slider itself into engagement with the pinion to take out any slack, but too much pressure makes the steering stiff and it doesn't self centre properly. Too little (as I have found) makes the steering extremely light and skittish. Like Goldilocks found, it needs to be just right. Don't worry about fine adjustment, just use trial and error and you'll soon feel what's right. I found 1/4 turn at a time is a good guide to be able to feel a change.
I found the random clicks have disappeared, I think it was through grease drying up and getting stick/slip of the rack occasionally. All the other joints in the column were absolutely fine, no slack or wear.
