Boost gauge and controller
Postby Austin Gillespie » Wed Oct 25, 2023 13:29
Hello, I'm looking to install a boost gauge (physical 1/8" tee type) and a mishimoto manual boost controller on my K6A cap, and trying to figure out which lines to tee into for those. Any help or diagrams would be greatly appreciated. Thanks!
Re: Boost gauge and controller
Postby Ian Linden » Wed Oct 25, 2023 14:31
The boost guage is easy. Just tee-off the pipe to the IAC Valve from the inlet. See Page 6E-24 in the Service Manual- the uppermost pipe in the diagram. Also Page 6L-5, 2nd diagram.
The boost controller needs to go in the pipe from the turbo to the wastegate actuator. Access is unbelievably difficult, but can be done without removing the turbo - small hands with strong fingers needed. See Page 6L-6 top diagram.
Be aware that raising the boost will run you into fuel cut if you go too far. There are also other pitfalls - please read the Performance Enhancement section of the turbo article in the Cappuccino FAQ.
Postby Austin Gillespie » Sat Oct 28, 2023 04:27
I have a EA21r, do you know how that differs in process from the ea11 F6A?
Postby Ian Linden » Sat Oct 28, 2023 08:32
Sorry, I missed that you asked about the K6A.
For the boost controller, see fig 13 in the EA11R Parts Catalog - the short hose to the left of the clip (Part No 36), is where you have to insert the two hoses to connect to the controller. You could get a workshop to replace the hose with a long length, which you could cut when you get home to insert the controller. See fig 14 in the EA21R Parts Catalog - the corresponding hose connection looks to me to be Part No 2 on the inset diagram, but I'm not sure the best way to address that.
However, I'm not sure whether the N1 ECU is applicable to the K6A - the Suzuki Sport ECU Manual does not include the K6A, so maybe it is not applicable, and I can't help further there.
For the boost gauge, there looks to be a fair number of hose connections on the intake manifold to tee into (see Fig 9 of the K6A).
Users browsing this forum: No registered users and 4 guests
