Ian Linden wrote:It's good that they can provide an EA21R thermostat for Oz, even though the car was never sold there - maybe it's also used on other models.
I never thought the gasket would be with the part - maybe if we could read Japanese we would have seen that !
Murray Betts wrote:Thermostats usually fail open, they're designed that way.
Murray Betts wrote:Is the radiator clean on the airside, and have you seen any signs of sludging in the coolant?
Do you have a specific reason for going away from ethylene glycol based coolant? I presume the waterless stuff you're referring to is propylene glycol, that's the usual base?
Murray Betts wrote:....blockages/restrictions somewhere, either water-side or air-side, or possibly even water pump vanes eroded away.
Chris da Silva wrote:Out of curiosity, if I required a new water pump (that is, if the vanes on the existing pump was eroded away) where in the parts book can I find the part number of the water pump? I looked through the exploded view diagrams and didn't see one. Presumably it would look pretty similar to the one for an EA11R...does it?
Ian Linden wrote:It's at Figure 18.
Using the Index system on the left, open up the drop-down "Parts Listings" under "Engine", and there it is. If you can't see the Index system, try another browser.
It looks quite different. The 11R seems to be gear-driven, whereas the 21R is belt-driven.
Users browsing this forum: No registered users and 15 guests
