Mounting a nose badge ...
Postby Chris da Silva » Sat Sep 21, 2013 07:56
Hi.
I just bought a nose badge for my Cappo and I need to know the exact spot on the bonnet on which to mount it. The badge is stuck-on unlike most car badges: it does not incorporate any locating pins (and neither has the bonnet any pre-drilled holes!).
That being the case, is there a template I could buy/borrow from someone? Thanks if anyone could help.
Chris :)
Chris da Silva
Images: 4
Re: Mounting a nose badge ...
Postby Ian Linden » Sat Sep 21, 2013 16:59
Mine is unsurprisingly on the centerline, and its lowest point is 19mm above the bonnet edge. That should fix it.
Postby Chris da Silva » Sun Sep 22, 2013 07:43
Hi Ian.
Thnx for that. :) Looks like I will have to exhume my old school set squares and ruler to get the badge mounted dead straight on the bonnet ... :)
On a different note, I'll be expecting my Cappo this coming week. I'll send you some initial pictures of it and an amended (updated) membership form ASAP. :D
Cheers
Chris
Chris da Silva
Images: 4
Postby Murray Betts » Sun Sep 22, 2013 19:35
Just to confirm what Ian says, that measurement ties up exactly with mine.
Postby Chris da Silva » Mon Sep 23, 2013 05:17
Thnx Murray.
OK - I have all the info I need now to get going.... :D Cheers!
Chris
Chris da Silva
Images: 4
Users browsing this forum: No registered users and 16 guests
