You can search various sites for the detailed technical stuff about Lube Oils (try
http://www.fernblatt.com/longhurst/ for a start, this chap knows what he is talking about
). The "W" number is the viscosity at
-18degC, and the other is at 100degC, so what is desirable is a low "W" number to get good cold start performance, and an appropriate hot number for the engine; Suzuki recommend a "30" hot end. I've done a lot of development testing of engine lube systems, and among other things the hydraulic lash adjusters in the valve gear work best with lower viscosities (better filling through the check valves). Unless you do regular cold starts below 0degC I wouldn't worry too much about the difference between 5W and 10W (or even 0W), they will all do OK, but you may as well go with a 30 hot end if available (having said that I'm currently using a 10W40 - doh!). The water/oil coolers (as on the Capp) usually work well, warming oil quickly and keeping it near coolant temp, minimising condensation, and the water cooled turbo bearing housing will minimise "coking". I doubt you're going far wrong. I'll be using a 30 at the next change.
