Notchy gearbox
Notchy gearbox
Postby Ian Linden » Sun Apr 08, 2007 09:30
I've been using Castrol semi-synth Syntrax Universal in my box, to address the notchy 2nd gear problem, and, as I reported, it cured the problem on all but the coldest mornings.
However, last year I spotted that Castrol had brought out a fully-synth gearbox oil called SMX-S, so I tried that.
After a year's use (the improvement was gradual) there is absolutely no trace of notchiness, ever.
Highly recommended for your Cappo, and well worth the extra cost.
Postby Lisa Balsom » Sun Apr 08, 2007 12:23
Thanks for the tip Ian.
Ours is a bit notchy going up through 2nd, and as engine and gearbox oil change is not too far away, we'll have to give that a go.
One question though, why do you think the improvement was gradual?
While on the subject of replacing liquids, has anyone tried Nesquik Magic Straws.
Really Good!
Lisa Balsom
Postby Ian Linden » Sun Apr 08, 2007 12:43
Lisa Balsom wrote: One question though, why do you think the improvement was gradual?
I really can't offer an explanation, but I noticed little initial difference to the Syntrax, and it seemed a bit better after say 6 months. I really noticed the difference recently; the symptoms have completely vanished.
Perhaps it's like wine - improves with age :wink:
Anyway, fully-synth is supposed to have good long-life properties, so I'm going to keep this fill in the box for a second year (car's only done 1,200 miles in the first year).
Postby Murray Betts » Sun Apr 08, 2007 19:17
I'll file that away in the "must remember" box. Thanks Ian. :wink:
Changing gearbox & rear diff oil
Postby Mark Dobson » Mon Apr 09, 2007 08:39
Ian,
Did you have much trouble in terms of access when changing the gearbox oil? I seem to remember a while ago someone was changing their gearbox and rear diff oil and mentioned the awkwardness of the job and how they discivered a few new swear words in the process.....
I bought some Millers TX semi-synthetic last year and have been put off replacing because of this
regards
Mark Dobson
Images: 5
Postby Ian Linden » Mon Apr 09, 2007 09:47
Hi Mark,
I think the greatest difficulty is working under the car. Even on axle stands, I found it too low and claustrophobic. OK for cavers, maybe :lol:
I confess I get a local garage to do it at annual MoT time. I just give them my oil and they do it on the lift. Being able to stand underneath, they have no problem.
I did try Millers semi-synthetic, but I found it not as good as Castrol Syntrax, and probably no better than mineral oil, as regards the crunch, so you may be disappointed with it. I know Dave Benson used to recommend Millers fully-synth, but I couldn't find any.
Now that Halfords stock Castrol SMX-S, I'm a happy bunny :D
Postby Lisa Balsom » Mon Apr 09, 2007 11:04
This thread may help,
http://www.suzuki-cappuccino.com/phpbb2 ... arden+hose
All we do is raise the front of the car and put the wheels on wooden blocks about 8 inches high.
This allows you room to slide under the car and undo and tighten the plugs.
The messy bit is performed from above and makes the job much easier.
For the diff, remove the rear bumper, which is really easy, and use the same method.
It can be unpleasant working with axle stands, but by using the blocks you are assured that the car is not going anywhere.
Hope this helps. :D
Lisa Balsom
Postby Mark Dobson » Tue Apr 10, 2007 20:47
Many thanks Lisa and Ian
Will get some Castrol and hold the Millers for another project, maybe the trike's rear diff will enjoy it!!!
regards
Mark
Mark Dobson
Images: 5
gear oil
Postby Martyn Collins » Fri Apr 13, 2007 18:59
This oil SMX-S sounds like the stuff to use.
How much do i need to buy?
Martyn Collins
Postby Adrian Furniss » Fri Apr 13, 2007 19:34
Martyn, see page 11-3 of the Owner's Manual.
SCORE Web Site Administrator
SCORE Classifieds
Regional Representative - Berkshire, Hampshire, Surrey, Isle of Wight, Channel Islands
Images: 46
Postby Tony Harris » Fri Jun 22, 2007 00:28
Can anyone confirm if it is SMS-X or SMX-S as castrol UK's website only lists SMX-S and so does Halfords, see;
http://www.halfords.com/webapp/wcs/stor ... &langId=-1
Castrol
http://www.castrol.com/castrol/multiple ... Id=7027191
Tony Harris
Postby Ian Linden » Fri Jun 22, 2007 07:48
Oops, sorry; it is, of course SMX-S
I will edit the posts above.
notcy second gear
Postby Martyn Collins » Sun Jul 29, 2007 23:43
just replaced the oil with this smxs stuff and it did the trick no more nochty second.
Martyn Collins
Re: notcy second gear
Postby Ian Linden » Sun Jul 29, 2007 23:46
Martyn Collins wrote:just replaced the oil with this smxs stuff and it did the trick no more nochty second.
Wow, instant success :!: :bounce:
Postby Dick Winchester » Sun Aug 05, 2007 10:59
So this new magic oil is OK for both gearbox and diff?
Dick Winchester
Postby Ian Linden » Sun Aug 05, 2007 21:24
Dick Winchester wrote:So this new magic oil is OK for both gearbox and diff?
EDIT: No, as stated below by Murray, it is not GL5, so gearbox only.
Use Castrol Syntrax Universal in the diff.
Postby Murray Betts » Fri Oct 26, 2007 14:52
Resurrecting this thread! :lol:
Just been trawling the Castrol data sheets (for work) and thought I'd check the SMX-S and Syntrax
SMX-S
DESCRIPTION
Castrol SMX-S is a full synthetic SAE 75W-85 manual transmission fluid.
APPLICATION
Castrol SMX-S can be recommended for most manual transmissions where API GL1-4 lubricants are required. It has been used successfully as a problem solver in the manual transmissions of a number of manufacturers.
FEATURES/BENEFITS
Excellent synchroniser performance giving extended synchroniser life and shift comfort
Exceptional cold flow properties giving smoother gear shift at low temperatures
High shear stability giving a constant viscosity during oil life and noise reduction
Excellent thermal and oxidative stability for transmission cleanliness and longer oil life
Excellent temperature reduction through reduced friction
Good seal compatibility helping to avoid oil leakages and repair costs
Free from chlorine and heavy metals giving better environmental compatibility
PERFORMANCE
SAE 75W-85
API GL1-4
TYPICAL PHYSICAL CHARACTERISTICS
Density at 15ºC 0.871
Viscosity at 40ºC, mm²/s 67
Viscosity at 100ºC, mm²/s 11.5
VI 164
Pour Point ºC -60
Flash Point ºC 228
Syntrax
Automotive Part Synthetic Gear Oil
DESCRIPTION
Castrol Syntrax Universal 75W/90 is a part synthetic multigrade gear oil which employs advanced technology additives to ensure extra protection at extreme low and high operating temperatures. Tested and proven, this SAE 75W/90 multigrade gear oil is synchromesh compatible and designed with a low chlorine formulation to allow environmentally responsible disposal of used oil.
APPLICATION
It meets the need for a 'universal' gear oil which can be used in automotive manual gearboxes, transaxles, transfer boxes and final drives where stringent performance specifications including API GL3, GL4 or GL5 must be met.
It is suitable for all units requiring a gear oil of SAE 75W, 80W or 90; including multigrade formulations within this range, e.g. 75W/90, 80W/90 and 85W/90 and can replace the following conventional Castrol gear oils:
Castrol EP 80 Castrol EPX 80W/90
Castrol EP 90
PERFORMANCE
API GL3, 4, 5
TYPICAL CHARACTERISTICS
SAE Viscosity Rating 75W-90
Relative Density @ 20º C 0.890
Viscosity @ 40º C, cSt 84.8
Viscosity @ 100º C, cSt 15.2
Viscosity Index 189
Flash Point (closed) º C 133
Pour Point º C -45
Significant points are that the older Syntrax is rated up to GL5 (suitable for diff), the SMX-S is rated up to GL4 (not suitable for diff which calls for GL5).
Postby Ian Linden » Fri Oct 26, 2007 15:08
Oops, don't know how I missed that. Well done, Murray.
I'll amend my post above.
Re: Notchy gearbox
Postby Ian Linden » Mon Jul 23, 2012 08:23
Resurrecting this thread again, to let everyone know that the current Castrol product for your gearbox is Castrol Syntrans Multivehicle 75W-90 Fully Synthetic MTF (Replaces SMX S 75w-85).
See http://www.opieoils.co.uk/p-739-castrol-syntrans-multivehicle-75w-90-fully-synthetic-mtf-replaces-smx-s-75w-85.aspx
For the differential, I think Castrol Syntrax Longlife 75W-90 is the one to go for:
http://www.opieoils.co.uk/p-737-castrol-syntrax-longlife-75w-90-formerly-saf-xo-75w-90.aspx
Re: Notchy gearbox
Postby David Brennan » Fri Jul 19, 2019 23:09
A third revival of this thread, I thought this would be a good place to account for my 2nd gear problem.
I've only bought my Capp this month, and the previous owner has put up with a 2nd gear blockout problem since he bought the car at just 2 years old in 1997.
My research before buying the car suggests that this box, in line with this thread had experienced plenty of 1-2 change grinds over it's initial 2 years of life. At present, the 1-2 shift is ok if not a little stiff but the 3-2 change is blocked out unless you either rattle the stick back and forth a few times, or double clutch.
Initially i assumed i'd just have to replace the synchro on 2nd but then thinking more about it, i figured it's probably had the collar and 2nd gear dog teeth flattened off from bad 1-2 shifts, causing the collar teeth to stick on top of the synchro teeth, rarher than pass by.
That would have quickly destroyed the synchro and resulted in my current problem.
I'm looking for a good 2nd hand box in Australia now, failing that i will order:
-2nd gear
-collar and hub assy
-synchro
-related springs
-seals etc
And I will pull down the box, post here with what i find and how the rebuild is to DIY, what the results are etc
-David
Australia (Victoria)
David Brennan
Images: 1
Next
Users browsing this forum: No registered users and 8 guests
