The Great Cappo Model Code Survey
Posted: Wed Nov 16, 2005 13:57
OK folks, let's try to get to the bottom of the Model Codes mystery (No that's not Muddle Codes, but...).
What we're asking is for everyone to open their bonnet and read the blue data plate on the bulkhead, near the battery.
It looks like this if the car is a JDM, or a different layout if the car is an export model:
What we would like to know, please, is the Model Code on yours. That's the field starting CAX (for JDM) or CAB (for export), and the VIN/Chassis Number (starting EA11(or 21)R, or JSAEEA11R). You can put Xs for the last three digits of the VIN if you wish.
Also, if the car is JDM, please tell us whether your car has:
I will compile the answers into a table, which will be posted on the board, so we can all have a go at deducing the answer.
- ABS (the unit is behind the carpet on the left of the boot)
- Airbag (the steering wheel has 4 spokes, 2 horn buttons and says "airbag")
- Limited Slip Differential (can't tell by looking, but jack up the back, gear in neutral (use chocks!) and rotate a back wheel - if the other turns the same way, it's got LSD)
- Any other "goody" which you think could have been a factory fit
