How do I disable the speed limiter?
Postby Barry Moore » Wed Jan 23, 2002 17:58
Is it as simple as cutting one wire :?:
Where do I cut :?:
Which wire :?:
What are the implications :?:
Will my speedo still work :?:
Can I fit a switch to turn it on or off :?:
Barry Moore
Postby Ian Linden » Fri Jan 25, 2002 00:33
Yes, but there is a better method
Where do I cut :?:
At the RSW terminal on the ECM (Electronic Control Module) near the glove box
Which wire :?:
Violet with red tracer
The engine warning lamp will light
Yes, if you have cut as above. No, if you cut the wire between the vehicle speed sensor and where it branches off to the speedo.
Yes, then you can get rid of the engine warning when its on
What is the better method :?:
Fit a "Speed limiter defencer" - a small box which will reduce the number of pulses passed down the wire, thus raising the speed limit. If inserted in the line as described above, it will not affect the speedo reading.
Why doesn't everyone do that, then :?:
Typically, the device costs about £100 , and it needs to be supplied with 12V power - the latter point should not be a deterrent
Could I make my own :?:
Yes, the components should be relatively cheap. When you've got it working, let me know what you used, so I can make mine :wink:
