Radio Connector Pin Assignments
Postby Ian Linden » Tue Dec 16, 2003 13:21
The pin assignments for the 8-way radio connector are:
Bl B - Left Speaker(s) (Main & Tweeter)
Bl - Left Speaker(s) (Main & Tweeter)
RG - Right Speaker(s) (Main & Tweeter)
BR - Right Speaker(s) (Main & Tweeter)
B - Earth return/Ground/Chassis
RY - Supply from Lighting Switch (side or headlamps ON)
WB - Supply from Radio Fuse (20A) (Ign. switch - Accessories or ON)
W - Supply from Stop & Tail Light Fuse (15A) (Always ON)
The color codes are in the Online Manual
I assume the W supply is for memory keep-alive only; it's use for the main radio function would create a risk of running the battery down, if one forgot to switch off :floods:
