So you will now see the day included like this:
rather than as it was before:Thu 18 April 2002 23:25
18 April 2002 23:25 pm
You'll also notice I've changed the time to the 24hr clock. I prefer the 24hr clock for this sort of thing but if I get a load of objections I'll change it back. I've started a pollbut I would imagine most people won't mind one way or the other.
You can always over-ride the way time is displayed for you personally by altering the setup in your profile. You can choose between Thu and Thursday, 12/24hr clock, display am/pm or AM/PM or non at all, include 1st/2nd/3rd/etc., and just about every conceivable option. If you don't like the changes you make simply change it back to the current setting which is:
- Code: Select all
D M d, Y H:i
Remember that internally the board will always be using GMT so if you are in a different timezone or using Daylight Savings Time/Summer Time you can also change the timezone that will be used for you whenever you visit.
