I've put this in Chit-Chat, because the car in question is a Suzuki Ignis (2005, not the current model).
The original radio/CD player died the death, so I've fitted a new Sony radio/media player. No problem until I connected the aerial and attempted to tune stations - I could only get hissing and one very weak station.
After a lot of head-scratching, I disconnected the car aerial, and plugged a meter probe into the center terminal of the aerial lead extension (still plugged into the radio), to act as an impromptu antenna. Suddenly, everything worked. More head-scratching, and I found I could get it to work from the car aerial if I disconnected the screen conductor at the end of the adapter. Reconnecting it produced the original symptoms. With the screen disconnected, there is no interference from the car's engine, so apparently no downside.
I then insulated the screen from the adapter plug, and I'm happy enough with the outcome, but I cannot understand what the problem was, and why breaking the screen continuity solved it.
Any ideas, please?
