by Murray Betts » Sun May 29, 2016 10:49
I've not heard of this being an issue but a good heads up, cheers.
Having spent many years in engine development I've seen various issues with crank pulley/damper fixings. It's very common to see "fretting" between the crank nose and pulley bore, it's a consequence of very small movement between the surfaces which is inevitable with any parallel bore design. You get the typical "cocoa powder" brown rust in the joint. Of itself it's usually nothing to worry about. The alternative is a taper, but even those aren't immune and have other issues (and cost) so it's something we live with to some extent.
Remember that the key is only for alignment, it should not take any drive through it, that should be entirely by friction due to the clamping load. Some engines have used "friction washers" which are impregnated with vary hard grit (often industrial diamond powder) to make a mechanical grip between pulley and crank, but that's a last resort really.
The most common reason for crank bolts coming loose is incorrect tightening in the first place, either under or over-tightening will do it. If in any doubt it's advisable to renew the bolt, but if in good condition with no obvious damage they can be re-used with no issues.
