Hi There All.
After being away for several weeks, and the poor old cappo being sat outside in all weathers, I took it out yesterday, apart from a flat battery all was well for about ten miles, then the gear shift seemed to stiffen up, quite suddenly, like it had dumped it's oil. It hasn't. Wear and tear would presumably be gradual in nature, this seemed to be fairly rapid degeneration, only in shifting, no problems with the gears themselves.
I did read former posts suggesting water ingress down the gear lever itself, not the box. So, how do I gain access? presumably by removing the centre console? I can find no reference in the manual, found the lever and explanatory diagrams, but not the centre console, which has the petrol cap release, window switches, rear screen mech etc. Don't want to proceed on a "trial and error" basis, as I seem to specialise in the errors mainly.
Is it listed in the manual? if so what page? if not, how should I proceed? Judging by "new" non genuine screws visible, I'm guessing this is not the first time access has been required, so probably a recurring issue.
Thanks for any advice.
Bill
