We have had problems over the last few weeks with the car battery going flat. Eventually traced this to the relay in the rear fog lamp circuit which is energised whenever the fog lamp switch is on, even with the ignition and the headlights off ! Becuase the lamp itself is not on (it needs the headlight circuit) the indicator on the switch doesn't show. We eventually traced it by putting an ammeter in the battery circuit and removing each fuse in turn and then identifying the relay in the UK addendum to the workshop manual (it isn't on the standard model).
This seems very strange wiring - I would have expected the relay to need the ignition so the fog lamp would only work if the headlights were on and the car running.
Is this a well known feature? Has anyone else been caught out by it?
I wonder if I could wire the relay into the warning buzzer for the lights?
Collette & David
Silver Cappo
Lewes
