It has been a few weeks since I responded to this thread. As stated earlier [in the thread] I would be updating some aspects of my "adventures" (for want of a better word) with the EA21R - so here they are.
The thermostat number which I gave earlier (part #17600-85811) was alas too small! I had the old part out and compared them; and the one from the [EA21R] Cappo is slightly bigger and off-centred! Then I looked at the next size up (part #17600-60814) and that was also off-centred but too big!! In the end, I acquired the correct part from Japan as per the parts book - part #17670-73G01 - which is an in-between size! Part #17600-85811 (as mentioned above) is for the EA11R and is concentric.
Note also that for EA21Rs with automatic transmission, the part number for the radiator cap (17730-12C01) has now been superseded to 17730-08J00.
After assembling the thermostat, I flushed the system through and topped up the radiator with Evans Waterless Coolant as I said I would. This weekend, I am going to take the Cappo for a spirited drive in the Aussie heat and see what happens. The glycol I had in there when I bought the car didn't do much, and the engine ran abnormally hot as indicated by the water temperature gauge. All things being equal, the temperature should now read Normal or slightly above!
Finally, the other piece of good news is that I had the power steering motor rebuilt! Considering that the complete sub-assembly (Part #48200-80F40) is no longer available from Suzuki, this was a sensible move!
At first I thought that the motor assembly was welded to the steering column when the assembly was still in the vehicle (it's hard to see when the column is still in situ); then I discovered that it wasn't when I removed it! 2 bolts held the motor flanges to the column, sealed with Lock-Tite(!!) and was a devil to get off! To cut a long story short, I had help in removing the bolts (thankfully undamaged) and peered into the motor casing!
Not only had the innards seized completely and burnt out thanks to rust and other corrosion (could be ingress of water, but the Lock-Tite which also formed a seal couldn't have let moisture in...) , but it also needed rewinding. This was duly done and now it works just fine. I'm pretty chuffed that the work put in has paid off handsomely!
C
